DesignSeries02298.pngEditing slab geometry with 3D modifiers
A slab can be modified by a 3D shape, such as an extrude, tapered extrude, extrude along path, sweep, solid, or closed mesh. These modifications allow a slab to have a ramp, add support beams, or include drainage features. The boundaries of the modifier can be specifically defined according to its shape, or they can simply be defined by the slab boundary.
Adding a 3D object to a slab
Command
Workspace: Path
Add 3D Object To Slab
Architect: AEC
Landmark: Landmark > Architectural
Spotlight: Spotlight > Architectural
To add a 3D object to a slab:
Select both the slab and the 3D modifier.
Select the command.
The Add 3D Object to Slab dialog box opens.
Parameter
Description
Add object to component
Select the component to be modified by the addition; all of the other components are clipped by the modifier
Clip object to component boundary
Trims the 3D object to the bounds of the selected component; this is useful for creating a sloping slab
Subtracting a 3D object from a slab
Command
Workspace: Path
Subtract 3D Object From Slab
Architect: AEC
To subtract a 3D object from a slab:
Select the command.
The 3D geometry is subtracted from every component that it overlaps.
Changing the slab modifier
Editing slab geometry with 2D modifiers
